SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
SOURCE: Roper washing machine not going through rinse cycle.
Good Morning,
Sounds like your cold water valve is not opening. If you are handy with a Multimeter check the selector switch that you use to set your cold water for good continuity when you activate it. You should have a good steady reading on the meter. If the meter is fluctuating or has no reading at all the switch is bad. If the switch checks out good, check to see if there is voltage to the cold water valve terminals when the machine is calling for cold water. If there is no voltage, you will have to locate the relay or source that supplies this voltage and replace it. If there is voltage the valve is faulty and needs to be replaced.
I hope I helped you today.
SOURCE: Cold water Washes
It is normal for the machine to cycle between hot and cold water when
filling even if selecting a cold cycle. The reason for this is because
even a cold cycle requires the water temperature to be 78F for the soap
to break up efficiently.
During the cold months the water in
your pipes is probably less than 78F so the machine will need to add
some hot water to bring it up to this temperature. Basically, it is
adding cold and then hot water to maintain a temperature in the tub of
78F for cold water cycles.
Hope this helps, please rate my solution.
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops
filling nothing happens. However sometimes it will go complete cycle
ans a noise can be heard on spin cycle even though it is not spinning.
As thoiugh the motor is not engaging with the cylinder
Was this helpful?
Yes
No
SOURCE: Is there any code where i can lock my washing
No code, but try this........Pull out the detergent dispenser by pushing down on the blue indented tab by the softener dispenser and take it with you
