SOURCE: My screen reads "camera error # E21"
On my LS 743 Kodak Camera, that error refers to a lens mechanism problem. I was able to fix it by removing my front cover which had be come dented inward and short circuited some wiring. Re-shaping the cover fixed the problem. This will probably void your warranty...
SOURCE: error #e21
Having had it for half a year - how come no warranty? If you acquired it through regular means and still have purchase documentation then back to the retailer it goes. The problems you mention are definite - firm ware errors and seller/manufacturer responsibility. Suggest you also contact Support on Kodak website to discuss the problem - you do no have to discuss source if that is an embarrassment.
SOURCE: lens error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuff It will be helpfull for you. Its is a step by step solution with images.
Regards
Mukesh
SOURCE: Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
support.en.kodak.com/app/answers/detail/a_id/1462/kw/error%20code%20E21/selected/true
