Sport & Outdoor - Others Logo
L
Laura Rizzo Posted on Sep 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The loop piece on my manual 16 ft outdoor awning brooke and i cannot reel it in...any thoughts
Chris Walker
Level 3:
Top Expert:
  • Sport & Outd... Master 1,573 Answers
  • Posted on Mar 16, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245431
Points
21965
The awning has two rollers and is manually operated, but we can't figure out how to use it
Teresa, I will post links to videos on awning set up and use. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Use the Awning on Your RV
RV Awning Tutorial
1 How to Open RV Awning
How to Use and Maintain Camper Awning Pete RV Service Tips
Instructions for operating rv awning
Manual or electric. If electric press the switch located inside the unit. If manual, you will need to go to each arm and press the release clips to unlock the arms (usually black but may be a lift up lock). Next tank the long rod with a loop on one end and a 90 deg hook on the other. Toward the front of the coach at the top of the awning you will see a small lever on the awning. Use the loop end of the rod to pull the lever down. Take the other end of the rod and insert it into the black strap that should be barely hanging down and pull down as you back away. This should pull the awning out. Once pulled out all the way, go to each end of the awning. Close to the wall of the RV there should be an arm hanging down with a knob on the back of it. Grab the bottom of the arm and slide it out and clip it into the end of the extended awning arm. Push down on the lower arm to tighten the fabric and then tighten the knob. Once both ends have been tightened then on the lower arm there will be a pull out handle in the middle, pull it out to release the lock pin and lift the outer portion of the lower arm up to raise the awning to the desired height. Repeat for the other end. If it is raining or windy put the awning away. DO NOT LEAVE IT OUT! The wind will catch it like a kite and rip it off of your trailer. Rain will fill it up like a swimming pool and collapse the center tube and trap you inside of the RV.
Should I get a motorized awning?
In case you don't want to hassle with manually deploying your awning, look for one that allows you to retract it with the push of a button.
What is motorized awning?
motorized awning feature sensors that cause them to automatically deploy when it's sunny or rainy and retract when it's windy to prevent damage, rather than doing it manually every time.
1helpful
I am trying to purchase a sunshine leisure executive 320 tent for the family I was told that the executive 320 was the largest sunshine tent, so I thought I would scan the net where I found you.
hi there, i have one for sale if you are still looking for one, yes they are the largest they made internal maesurements are 14' x 16' plus an 8' awning. please email me at [email protected]
2helpful
How many winds on the tension spring for a dometic 9100 series awning for initial setting? I heard 1-2 feet out from coach, wind 13 times is standard
2 ft away from coach,wall, awning rail etc.
up to 12ft long awning = 8 turns
13-14 ft = 9 turns
15-16 ft = 10 turns
16.5 - 18ft. = 12 turns
19 ft-up = 13 turns.
Be real careful, !!! seen many a finger/hand injured if not experienced.
2helpful
As I was cleaning my Zebco reel, a shiny piece fell out of it, and it looks almost like a piece of a puzzle. Can someone tell me what this piece out of my reel is and how I put it back together?
the shiney pc is the stop so your reel wont go in reverse.look at where the crank go's through the boby of the reel.there are little teeth on it.the little shiney pc =(reel stop) go'e in that little slot under the crank shaft.
6helpful
2answers
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
