Refrigerators Logo
Anthony Bishop Posted on Sep 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cda fridge a lot of ice at the back - CDA Refrigerators
john h
Level 3:
Top Expert:
  • CDA Master 29,494 Answers
  • Posted on Sep 21, 2018
john h
CDA Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7560504
Points
193449
Coil freezing up possible fan failure
My K40 is producing ice, but theres a lot of water underneath the ice. What to do ?
I'm guessing that this is an ice maker in a refrigerator? My fridge had the same problem. As it turned out, gravity was the problem. My fridge was tilted back too far and wasn't level. I leveled it out and the water stopped sloshing backward over the chute and into the molds where it belonged. good luck.
My fridge alarm keeps goin off and the inside the fridge is warm
It is very likely the defrost element has failed so it will just ice up in the back where you cannot see. Maybe switch it off for 24 hours and see if a lot of ice melts and then restart.
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Refrigerator cooling defrost freezer
Buy a freezer thermometer from any supermarket, it has a guide.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
1helpful
2answers
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
The freezer works, but the ice cube maker gets frosted up, and the refrigerator barely gets cool
Make sure the fan is running in the fzr the fridge side steals air from the fzr via a small duct to the fridge. If there is a lot of frost you may have an ice block on the cooling coils in the fzr usually behind a back panel. If you have an ice block your defrost timer,heating element, defrost limit one of these could be bad. Let me know if you find an ice block or a lot of frost. good luck
Leaks water in fridge wich turns into ice.
ur drain ir clogged in freezer. remove back panel in freezer and unclog small hole
I have a CDA integrated fridge/freezer, the fridge is working but
OK then have a look at the back wall of freezer is frost building up on rear panel?
How ican conect my ipod
here's your best start...
jump on eBay and type in your model number: CDA-9857
Lots of the ipod input adapters out there on eBay.
The adapters hook up to the back of the Alpine CDA-9857 deck.
1helpful
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Top CDA Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a CDA Refrigerator Expert? Answer questions, earn points and help others
