Bernardo Silva Posted on Sep 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Konica Biz C451 starts print in color with full 100% Magenta.
While printing im black only it was Ok but after couple jobs start faiding
Norman Weimar
Level 3:
  • Konica Master 7,035 Answers
  • Posted on Dec 24, 2018
Norman Weimar
Konica Master
Level 3:
Answers
7035
Questions
Helped
1913973
Points
11960
Replace the magenta image unit and the black image unit
5 Related Answers
dan862
  • Posted on Nov 19, 2007
SOURCE: prints black on test page, but not when a job is sent to the printer
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Anonymous
  • Posted on Jan 30, 2008
SOURCE: Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Anonymous
  • 167 Answers
  • Posted on Feb 17, 2009
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Anonymous
  • 67 Answers
  • Posted on Mar 30, 2009
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
William Charnigo
  • 615 Answers
  • Posted on Mar 28, 2010
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
1helpful
I have a konica minolta c250i, the magenta is not printing on the paper, it print out as yellow. other colors are perfectly ok
There are several reasons why your Konica Minolta C250i printer may be printing magenta as yellow. Here are some troubleshooting steps you can try:
  1. Check the magenta toner cartridge: Make sure that the magenta toner cartridge is properly installed and has enough toner. If the toner cartridge is low or empty, replace it with a new one.
  2. Clean the printer heads: Use the printer's cleaning function to clean the printer heads. This can help remove any clogs or buildup that may be preventing the magenta ink from flowing properly.
  3. Check the printer settings: Check the printer settings to make sure that the correct paper type and color settings are selected. If the printer is set to print in grayscale or black and white mode, it may not use the magenta ink.
  4. Perform a firmware update: Make sure that your printer has the latest firmware installed. Sometimes firmware updates can fix issues with printing quality.
  5. Contact Konica Minolta support: If none of the above steps solve the issue, you may need to contact Konica Minolta support for further assistance. They may be able to diagnose the issue remotely or send a technician to your location.
I hope these steps help you resolve the issue.
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
Hi, on Konica-Minolta Bizhub C450 printing speed is very slow. Attached to Ethernet, Data via TCP/IP. Speed 100 MBit fullduplex. Sending a full color A4 page with 300 dpi; f. E. from...
Am having little Challenge if I send job to printer Bizhub c451. D job will enter printer and it will wrote System Printing and it will not print
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Top Konica Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
NOEL
NOEL
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
