These are few minutely drafted steps to help you out for the wireless set up of HP Office Jet 8702 Printer for the first time. Pursue this very cautiously:-
At HP Printer Customer Service Number you get the best wireless connection set up method. Dial if you are facing any kind of issues that might have come across. We overcome these errors excellently without any difficulties! We have software engineers! We are 24X7 on desk ready to help you anytime for 365 days, take a leap of success, save time!
or check out this: https://www.printertechssupportnumber.com/enjoy-learning-how-to-create-hp-office-jet-8702-printer-wireless-setup/
It is a common error that may occur in the HP Officejet Pro 8710 model. Select the paper size correctly and set the paper tray properly.
Assure the cartridge is placed at the respective slot. Make sure that there is no dust or smears in cartridge.
Check the ink level as well and resolve the errors by quick and easy way. Visit https://www.123-hp-com-ojp8710.com/ for troubleshooting errors or call us to the toll free number @ +1-866-680-8875.
The Officejet 8710 printer can face paper mismatch issues if the paper settings are not set properly in the Print Preview box.
Try setting the Paper Type option to Plain in the settings window that appears before performing the print.
Change the settings to 8.5 x 11 in both the copier and the printer setting.
There can also be an issue with the paper tray.
Set the paper width guides correctly.
Try printing a Configuration report to determine which paper size the printer is configured to.
Any bits of paper stuck inside the printer roller might also cause paper feeding errors.
Open the cartridge access door of your HP Officejet Pro printer.
Wait for the ink cartridges to a position on the left.
Look for any pieces of paper inside the cartridge area.
If any bits are found, remove them. That should solve your problem.
for more support Call our Toll-Free 1-866-293-9220 or visit https://goo.gl/Pkv63e
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
SOURCE: There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
SOURCE: Office Jet pro L7500 paper jam - how to open printer?
hi!!! in your case my advise to you is to open the duplexer located at the back of the printer and look if there's a stock paper or any material that can cause paper jam to your printer.
SOURCE: "Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
SOURCE: Paper size error when copying - Office jet 7210
I got the same error, and had it for months. open the ink door where it says office jet pro, it folds towards you, wait for the ink cartage to position to the left, then look inside and far to the right, and see if there is a wadded up peace of paper inside. Reach in and pull it out, it fixes the problem
