Samsung SCX-4521F
Read the quick summary given here when you are struggling to scan to PDF.
1 Connect your printer to the computer using a USB cable or a wireless router.
2 Place the document that you want to scan on the scanner glass.
3 Click the Start menu and then select the option called Fax and Scan that is displayed in the printer shaped icon.
4 Click the New Scan button to open a new window.
5 Open the Scanner section to view the list of scanners if you have connected many.
6 Click the Change button to choose the exact scanner you use.
7 Select the Profile drop-down list and click on either Photo or Documents to choose the document type.
8 Select the Scanner type under the Source drop-down box.
9 Choose the Printer option and select Microsoft Print to PDF.
10 Choose the Printer option and select Microsoft Print to PDF.
11 Click the Save button and then enter the name of your PDF file under the File Name field.
12 Select the Save button to save the file in your desired location.
To Get Instant Support Call our Toll-Free 1-866-293-9220
W10 has this built in
so what PC is this what OS?
HP now owns samsung printers .
there are only 4 ways,
use w10 print engine way,
use HP way if offered, ask them yet?
or scan to JPG
and use and app to publish jpg to PDF, I use NITRO.
or buy PDF engine driver, to do that.
Samsung SCX-4521F Laser Multifunction Machine Print/Copy/Fax/Scan
SOURCE: Scan format - Samsung SCX-4521F to PDF
samsung scx 4521f in black background in more verticle white line in
SOURCE: scanning document in PDF format
To scan in PDF, you must have a PDF scanner please download and install a program like scantoPDF or others that you can use, like, NitroPDF, or Adode Professional, Either that or you can simply convert the JPG, to a PDF, with a printer, a virtual printer that "Prints" PDF, as PDF is a printing format, and it is done in software. So there is Print2PDF, PDFPro, and many others that will scan and print also you can get a PDF plugin for MS WORD as well.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=scan+to+PDF
above is your link for scan to PDF & Below is the Print to PDF.
http://www.google.co.nz/search?num=100&hl=en&q=print+PDF&aq=f&aqi=g-c1g1g-c8&aql=&oq=&gs_rfai=
SOURCE: how to multiple pages scan
Try installing this and using the auto-feed feature to create multiple pages. If not using Windows there is another program called Imagejack that will work for Linux, Mac,etc.
Hope this works for you
http://wareseeker.com/Graphic-Apps/image-anvil-2.0.5.zip/10503
