Tools & Hardware - Others Logo
Yaros Davidovich Posted on Sep 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove jammed staples from Stanley electrical TR700?
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244322
Points
21965
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Sep 28, 2008
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Anonymous
  • 152 Answers
  • Posted on Mar 22, 2009
SOURCE: Size of staple to install roll insulation in wall cavities.
It would seem that 9/16 is a bit long to attach canvas and may even penetrate through to the working surface unless the backer board is much thicker then 9/16.
1/4 or 3/8 may be more suitable.
Good luck
Aduz
Anonymous
  • 384 Answers
  • Posted on Sep 09, 2009
SOURCE: stanley bostitch electric staple 02210 won't
You must have bought the Southern model. We work at a little slower pace here.
thesnooper
  • 342 Answers
  • Posted on Apr 05, 2010
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Anonymous
  • Posted on Oct 26, 2010
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
I have a Stanley professional 69-500 I put the Staples in and the handle will not release all the way down what could be the problem
Double check your using the correct size staples, there are a lot of different sizes and types out there. I've made that mistake.
The most common reason is that it has jammed on a staple. remove the staples and the rod that holds them in place. See if the stapler will work when empty. Keeping you hand away from the trigger arm Carefully look to see if there if a staple jammed in the release slot. Sometimes you can clear jams with a small, flat blade precision screwdriver.
Stanley Sharpshooter electric staple gun
Strip it down and clean it out, or at least get an airline in there. It is either rust or something inside breaking down.
https://www.google.com/search?q=Stanley+Sharpshooter+electric+staple+gun
How to fix the spring in my Stanley electric stapler tre550
  • Step #1 - The first step would be to release the trigger and then unplug the device. If you notice that your gun is jammed, never try to dislodge it by repetitively pulling the trigger. The internal safeties of some models are capable of preventing the device from firing. Once you've released the trigger, unplug your corded model, and turn off the switch if the gun has one. If you're an owner of an electric model, on the other hand, you can simply remove the battery pack. Similarly, the pneumatic staple guns should be released from the air hose.
  • Step #2 - Now would be the time to remove the staple clip. Most models have a small release lever that's located at the bottom of the magazine, which you should pull and see the magazine get unclipped. After that, you can pull on the magazine until it's disconnected from the tool.
  • Step #3 - The next step is to take the needle-nose pliers and remove the staples. Some jams will be caused by the failure of staples to get properly ejected from the magazine - they might even be squashed by the other staples in the magazine. In other cases, the staple has left the magazine but only partially, and is stuck in the gun's opening. No matter what your particular situation is, take a pair of pliers and pull out the staple from the place it's stuck at. Do it gently as hasty action might cause damage to the magazine.
  • Step #4 - As we said, the discharge area is another place where the staples might get stuck at. For some models, you won't have to use the pliers - a tap on the base of your model might be capable of clearing the jammed staple. Check the user manual to find out if your model can do this.
How do I load the stapler?
Search Results
    Stanley electric stapler/brad nailer - YouTube
    ? 5:06
    https://www.youtube.com/watch?v=Zbgt2UXpS-M
    Dec 29, 2013 - Uploaded by Tindlez
    How to load staples and brad nails in Stanley electric staplermodel TREE550 ... Stanley SharpShooter Manual Staple and Brad Gun review ...
    Stanley Electric Staple/Nail Gun (TRE550) - YouTube
    ? 5:04
    https://www.youtube.com/watch?v=6JTZJjQ3wlA
    Jan 5, 2015 - Uploaded by HowToWith GEO
    This video tests the Stanley electric stapler and nail gun. Model TRE550. This video will test both staples and brad type nails. ...Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. Unpack Guy 43,106 ...
    Safety Tips for an Electric Stapler : How to Load Staples into ...
    ? 1:01
    https://www.youtube.com/watch?v=dMsdmYBoojU
    Feb 5, 2008 - Uploaded by expertvillage
    Learn how to load staples into an electric stapler in this free educational video ... Stanley Electric Staple/Nail Gun (TRE550) - Duration: 5:04.
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
My Stanley PHT150 is jammed and I cannot remove the staple channel. The instructions do not address a jammed staple channel so, how does one remove it?
Hi Dave,
Nice and easy this one.... all you've got to do is remove the chrome coloured pin at the handle end. This then allows the magazine to be removed by pulling it from the front end. Just make sure that you've removed the pusher (Where you feed the staples in) from the back first
1helpful
I have a jammed staple in a bostitch staple gun ....how do I remove it?
Depending on the model that you have, for the manual guns, you can engage the driver 1/2 way and use a precision screwdriver to free the errant staple. However, if it's the electric model, you'll need to unplug the tool, remove the magazine mounting screws, and clear all material from the feed tube, this should also remove the lodged staple as well. If not, rap it against a wooden surface to free it then reassemble. I suggest that you unload your tool between uses to keep the rigidity of the spring up to OEM specifications. A weak spring is usually the cause of these jams.
My stanley model tr 250 seems to be jammed up and won't load staples
Generic comment.
There should be a pin or a screw (probably with a locking nut) on the business end of this machine. Find it, remove it and the track should pull down allowing you to clear the jam.
I hope this helps
a
Top Stanley Tools & Hardware - Others Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
