The language preference will be under "OSD" in the set up menu. Found a link to the page that is in the users manual for a Skyworth TV -
Skyworth LED 32E60 Instruction Manual Setup Settings
Testimonial: "Thanks, cannot read Asian Language. Everything is written in Asian of some sought...."
When you use the remote to get into the menu settings, a bunch of icons will appear on the top of the screen. The page I linked you to should be similar or the same as the menu on your TV. The selected menu in that image that looks like a clock gear is the set up menu. The first item is OSD Language(on screen display). Use the arrow pad to go left and right until the selected language is English.
SOURCE: Change Language Setting on W375
Hello there. please do the following. press the menu button>press the screwdriver option>press the wrench with a brown file icon>go down 6 places from the top and select it> you will then see english at the bottom. hope i helped!
SOURCE: Need to perform factory reset
When I worked for Philips, I solved one of these. First, try unplugging the unit from the wall outlet for one full minute and see if that alone will reset the unit/restore it to defaults. If not, make sure you have a yellow video connector running from the Bose to your TV rather than another type of video cable - change the tv to the appropriate source channel - now see if the menu will appear. If not, you will have to fly blind (don't mess up): Press the System button, then the right arrow by the Enter key twice, then the down arrow by the Enter key five times, then press Enter. Defaults (including NTSC) will now be restored.
-Tha Mp3 Doctor
SOURCE: i need to change the language of the menu back in english
hi this is singh i am having d same phone , u do 1 thing go to menu n click on d icon which is symboled by a srew driver and then press down button in ur key pad for four times and then press center button n then u will find the english selct dat option n press save button which appears in chinese language ok njoy
first of all press the top most right button, then using the scroll go inside the settings icon . the settings icon will have a wheel made on it, then select the top most icon n then select the 7th option in tht select the language
SOURCE: lexmark 4550 language setting cannot change from set-up
the tip shared in the first paragraph of
rhong on Nov 28, 2008 was PERFECT , it is not only to press start color and back key with power button until it shuts down it is to turn the power button on while pressing the back and start color keys.. a little note comes on the screen saying "lang cleared" ...
THANK YOU RHONG !!!!
