Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
you need to change the paper size or font size in the software that creates the printout. if you can, do a print preview before you print to see if its going to try and print to one page
Sounds as if the format is wrong. You must set the paper format in the PC wordprocessor or invoicing software to the same size as the actual paper size of the invoice.
MyInvoices & Estimates Deluxe Open Company file error. Exception: Unable to load DLL 'sqlceme35.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
