Plz
SOURCE: Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
SOURCE: Printer will not use cyan
Well I just bought a brand new Kodak 8500 and purchased a few boxes of the 25 1400 print kits after getting it I thought it would be as easy as the Kodak Easyshare 4x6 printers BUT thought different after trying my first box of 25. I got 10 good prints out of 25 due to paper jams after 2 passes. I did the alcohol thing on the LED and sensor and that worked good for 1 full box of 25.
I then loaded a box of 50 8500 ribbon and paper same problem more paper jams after 2 passes wasting more $$$.
I did the whole routine as stated above and after taking the whole darn thing apart I did 1 more mod. I turned the potentiomter 1/2 of a turn but then drilled a small 1/2 hole in the forward plate where that pot is and reamed it out to over 3/4 on and inch thus if you need to make further adjustments you do not have to take the whole thing apart again, just the lower front cover. Because when the front cover is removed with the 5 screws and not 4 the whole darn circuit board falls out and its hard to get the plastic protective strips covering the top and bottom to align back up to slide it back in place. SO with the hole drilled there you do not have to bother with that ever again. After doing the les than 1/4 of a turn I still had a problem and yes I did put it all back together,
BUT at this point I removed the lower front cover and had access
to the pot again and moved it another 1/4 of an inch clockwise installed the 2 screws tried again and I ran a whole box of 50 without a problem.
I don't know if I'll have anymore problems but If I do I'll post it.
SOURCE: printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
