Question about Zanussi Washing Machines
On the Zanussi zsf6161 no red lights appear when machine is turned on and error 50 appears only seconds after starting any programme
    Master:
  • Zanussi Master
  • 509 Answers
I50 - on your dishwasher means "Motor triac short-circuited"
(the washing pump runs uncontrolled at maximum speed)
Remedy: it is mostly circuit board faulty
Dado
Posted on Jan 12, 2019
SOURCE:
  • 38 Answers
SOURCE: zanussi zdt6053 will not fill with water
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Posted on Jan 15, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
I had the same problem today - machine is two years old - cannot select a program - door does not close properly - the machine should bleep at you when the door opens or closes.
Problem is the catch - its has a powerful spring on the catch which in time distorts the two plastic bearings each side of the catch which then stops the door open switch working.
The fix is simple - new catch mechanism available from :-
http://www.espares.co.uk/part/dishwashers/belling/p/1083/154/0/0/551313/door-catch-assembly.html
Stock Number: ES551313
Price £11.49 Regards  - - - - - - Alan.....
Posted on Jan 31, 2009
  • 15 Answers
SOURCE: All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Posted on Jan 12, 2010
  • 597 Answers
SOURCE: Magnavox 50ML8105D 50 in. HDTV DLP TV: I cut my magnovox on and in 20 seconds it cuts off...
Contact Magnavox tech support
Posted on May 20, 2010
No red lights appear when machine is turned on and error 50 appears only seconds after starting any programme
Well u kinda have to be more specific. Are u talking about a fridge, washer, UFO, car, house, phone, etc?
Sep 02, 2018 | Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Zanussi zwf1621s washing machine not working.
IT SOUNDS AS THOUGH THE MOTHER BOARD HAS SHORTED OUT OR YOUR DRUM HAS COME AWAY FROM ITS MOUNT
Dec 27, 2013 | Washing Machines
Zanussi ZSF6161 dishwasher. the program starts, I can hear some water being moved around then it stops. All happens in the first minute. There is no error code, it just humms it's way down to the end of...
Maybe a clogged pump. Take the pump a part and clean the filters and inside the pump. Check to see if there is food jammed in the hoses while you are at it.
Oct 31, 2013 | Zanussi Dishwashers
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Jan 12, 2010 | Washing Machines
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Error 54 comes up when you switch it on
all error 50 messages relate to the motor.
Feb 13, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
986 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
