Cameras Logo
G
Gordon Dinner Posted on Aug 29, 2018
Canon 5d won’t turn on and battery buzzing - Canon Cameras
iMedia fixer
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jan 21, 2019
iMedia fixer
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
6279
Points
63
Sounds like you have a defective battery, insert another.
1 Related Answer
Anonymous
  • 178 Answers
  • Posted on Jul 02, 2010
SOURCE: attach strap to canon BG-E6 and 5D
Cannon lp-e6 battery fit canon eos 5d mark ii http://www.canon-digital-camera-battery.co.uk/batteries/canon-lp-e6.htm
My Canon 5D mkI turns on ok, will focus, displays top and back, but it will not take a shot. I have two batteries, both which I have charged to full and tried (display shows full charge). I have also...
hicould you tell me the amount of shot number when you put memory card in? If yes, please move to manual position from auto on the side of lens. And try to press release button.there is other one thing you have to chack selftime release working or not. just let me know.
1helpful
I have a Canon battery grip for my Canon EOS 300D but have no manual to tell me how to use it as the camera is 2nd hand, can i get a manulal or download one from anywhere
I understand there isn't a manual, just a quick how-to guide. Here's some basic use info from a review
http://www.the-digital-picture.com/reviews/canon-bg-e6-battery-grip-review.aspx
The Canon BG-E6 Battery Grip is designed specifically for the Canon EOS 5D Mark II as shown above with a Canon EF 16-35mm f/2.8 L II USM Lens mounted. To get the Canon BG-E6 Battery Grip into the position shown, the LP-E6 Battery is removed from the 5D II and the battery door detaches. The BG-E6 slides up into the battery compartment and locks into place via the tripod socket screw seen on the BG-E6 just below the lens in the above image. The BG-E6 provides its own tripod adapter threads - this functionality is not lost.
The Canon BG-E6 Battery Grip holds two Canon LP-E6 Batteries that deliver double the number of shots or video time from the 5D II. Alternatively, use 6 AA batteries in the included Canon BGM-E6 Battery Magazine shown below.
2answers
I keep keep an error 20 message with a canon 5d markii. It says to take out battery or turn camera on and off. This didn't work.
If the problem still happens after multiple resets contact the place you bought the camera from and see if you can get a replacement. If the camera is still under warranty canon will try and repair your camera and won't replace unless it is unable to be fixed.
Canon 5d lcd
If its a year, request that canon fix it free of charge under its warrenty.
Charge the battery, and or buy a new battery to see if its fixed. Bestbuy if there is one close to you is the first place I look for a battery.
Canon 5d
Make sure you have your flash & timing set where it is supposed to be, usually between 120 & 180. This is the shutter timing and flash duration. It is the syncronizing speed setting. If possible, turn off the automatic review, this slows things up. Also, if possible, use a power cord for the flash instead of batteries. Not all have this feature but, the flash is ready for the next shot in about 1 second.
No shutter actuation, no menu display, no autofocus.
check the battery and flash card doors. are they propely shut?
2helpful
3answers
Canon 5D won't turn on
Response from Guest posted on Apr. 01, 2008
Sent and received my Cannon EOS-5D from Canon and they replaced the power supply assembly. It had shorted out. They did not tell me why it shorted out so I'm left with the question of what is/are the event(s) that caused the power assembly to short out. I don't have a warm and fuzzy feeling that the problem has been fixed.
Guest
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
