SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: how to decode signal coming to the arris modem
I'm not exactly sure what you are asking but these arris modems have a built in website where you can check statistics, etc. What you would do is open up your web browser and punch in I believe 192.168.1.1 into your address bar.
SOURCE: Moden and Router aren't connecting to wireless laptop
It sounds like the router is working OK, so there's really no need to reset it. Here's some things to try, in order:
1 - Click Start, then run. In the box that appears type cmd and hit enter. This will open a DOS Prompt. At the prompt type ipconfig and hit enter. Your IP address should read 192.168.1.(some number). If it shows anything else, this indicated that you are not getting an IP address to the device.
2 - Click Start Control Panel. In control panel go to network. This will show you your available network interfaces. Reply here with the connections that you see in the box.
SOURCE: I have an Arris modem
Taken from the user guide:
http://www.arrisi.com/support/guides/_docs/TM502_User_Guide.pdf
Wiring Problems
If the Telephony Modem begins flashing all its lights for more than 10 seconds, this indicates a problem
with the telephone wiring — the red and green wires may be shorted (touching), or there may
be undesired voltage on the lines. If this pattern persists for more than 10 seconds, disconnect the
telephone lines from the Telephony Modem, then call a wiring technician for assistance.
SOURCE: i have arris tm502g modem n want to hook up 2nd pc wont work
You need a router or network switch to share the single connection from this cable modem. Wireless router if you're so inclined. Comcast is about to jack the rental rate for that modem from $3.50 to $5 on January 1, at least in Atlanta.
