Change out the water valve. The water valve is what the water hoses are hooked up to on the rear of the machine. This is a pretty easy replacement. The new one goes on like the old one comes off. Turn the water off and disconnect the water hoses from the back of the machine. Sometimes there is one hex head that is removed and the valve tips out for replacement. Depends on the year and model.
SOURCE: Wash cycle water is not hot for Speed Queen AWS53NW
Possibly a stupid answer..most water supplies at the hose connection have valves...turn off or at least reduce the amount of cold water with valve closed or partially open.
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
SOURCE: cold water inlet not allowing water through it
Here is a tip that I wrote about no water coming into the washing machine...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
