Good anser, thank you
http://www.flightline-rc.com
http://www.flightline-rc.com/
SOURCE: Honda GX 340-Used to start and run no problem, now nothing
I think both problems could be wiring in the key switch box. Sometimes the connectors shake loose.
SOURCE: New 27 MHZ Helicopter Controller won't turn on
I have a 27Mhz helicoper (looks identical to the one on the picture). I tried to fly it for the first time, but I am having problems controlling it. The left radio control lever sends the helicopter upwards, but the right hand control doesn't seem to do anything and that should make it go backwards and forwards. Can anyone help me as well please?
SOURCE: roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
SOURCE: Just bought an S107G. I have brand new batteries
Do the lights on the heli come on?
Normal start-up would be:
Turn helicopter on. Flashing light in nose should come on, as well as another blinking light (sometimes towards the rear, sometimes in the "cockpit" area) the helicopter MUST then be placed on a level stable surface until the 'other' light stops blinking, usually a couple/few seconds. This is the gyroscopes synching up and determining the "level" head orientation they will be maintaining. Then power the controller on. Making sure you're not covering the front of the controller with your hands, (the IR signals come out the front like a TV remote) push the throttle control (left joystick) up until the blades move. This what the horribly translated instructions mean by setting the helicopter and controller together.
Don't charge with the controller. It kills your controller's batteries, (which will last nearly forever if you don't use them as your heli's charger) and seems to make the birds act weird. Use the USB charger and a fully powered USB port (back of your desktop, not the front) and go by the light on the charger not an arbitrary time. Plug in charger NOT connected to heli. Look at the light. That is what the light will look like when unit is fully charged. Make sure heli is off. Plug into charger. Charge until light is fully on. If you unplug heli and the light gets brighter, it's not charged fully. A weak USB port (on a laptop or the front side data port on most desktops) may take several hours to achieve full charge. Always cool 10 mins after charging AND 10 mins after flying. Never drain fully, it will kill the Li/Po battery. Land and power off as soon as you can't maintain altitude.
If it is really charged, and you turn it on and nothing happens... no lights nothing. Then it's defective/toast. Return for refund.
These SYMA helis are awesome, and HANDS DOWN the best on the market... but they can be picky/tricky on how they are treated.
Please let me know if this helps.
PvT
SOURCE: My air hogs sharpshooter is
I have the same problem. I called air hogs. BIGGEST WASTE OF TIME EVER. They told me what I already know. After 20min, they told me there so called "diagnosis". They said "your air hogs sharpshooter is not charging". Idiots.
