Televison & Video Logo
Juan Williams Posted on Aug 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on my Sony XBR makes a small popping sound and doesn't come on?
Russ Hill
Level 3:
  • Sony Master 4,057 Answers
  • Posted on Aug 15, 2018
 Russ Hill
Sony Master
Level 3:
Answers
4057
Questions
10
Helped
1177513
Points
12696
Thats the capacitors blowing up or cooking they will need replacing.
5 Related Answers
Anonymous
  • 178 Answers
  • Posted on Sep 02, 2009
SOURCE: No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Anonymous
  • 1274 Answers
  • Posted on Feb 23, 2010
SOURCE: I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Anonymous
  • 184 Answers
  • Posted on Aug 05, 2011
SOURCE: 2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Azrael SRL
  • 11800 Answers
  • Posted on Sep 03, 2011
SOURCE: Sony XBR 40" tube tv.
Failure of the vertical deflection module/circuit. The tv will have to be opened, the vertical deflection circuit found and replaced.
Definitely a job for a pro - the circuit is going to be extremely difficult to extract. The repair will cost you about $200: $20 for a new circuit and $90 per hour for the 2 hour job.
gopakumarg43
  • 76851 Answers
  • Posted on Jul 22, 2013
SOURCE: I have a Sony trinitrotoluene xbr and when I turn
It sounds like an IC fault. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. If you wish to get more details about the blinking codes to Sony Trinitron, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Sony xbr-49x900f tv has sound but no picture after a min or shorter
Hello
in this case ld board is defective please replace ld board .
thanks
M Nasir
I have a Sony trinitrotoluene xbr and when I turn it on it makes the sound as if it was turning on then there's a click and it doesn't go on. The standby led is flashing six times in it cycle. How...
2helpful
6helpful
2answers
I have a small green vetical line in my sony bravia xbr 52"
Unplug the TV , the hard reboot will cause the line to disappear in a few minutes, must be some algorithm that kicks in
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
