I have a Cricut Maker and cut iron on vinyl, four different colors, to create a design. When i weed and put the colors together, they don't line up as the original in my workspace does. How do I fix this problem?
SOURCE: cricut wont cut
My wife's Cricut recently developed the same problem. I work on computers and mechanical stuff, and figured it couldn't hurt to open the machine for a look. What was happening was that the solenoid (like an electromagnet) that pulls the blade down into the paper has stopped working. I don't know if the solenoid itself has gone bad, or if one of the two wires leading to it has fatigued and broken. Whatever the case, my wife called ProvoCraft, and the rep told her it wasn't repairable and she'd have to buy a new one. Personally, I'd like to try and fix it first...
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
[email protected]
SOURCE: the cricut expression blades do not cut and I have
melenddia,
Is there a white tape sticking out of the lower back portion of your expression? This sounds like my problem.
SOURCE: WHen the cricut is cutting it tears my paper even
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
SOURCE: jpeg file onto a cricut
It depends on which Cricut machine you have. If you have the expression 1 machine this can be done with 3rd party software that is no longer available but can be found at times on ebay. If you have the Cricut Explore there is no problem importing jpeg, png, bmp, giff dxf, and svg files as well if you have any cartridges for the cricut these can be used as well.
