Too many possibilities and limited information. Does the engine still run and the car does not move? Or is the engine not running so that the car stopped? Repost the question with additional information.
This is the "Low Oil Pressure Warning" light. It is RED for a reason! When this light (or any RED warning light for that matter) comes on, pull over and shut the engine OFF at once. Allowing the engine to run with insufficient oil pressure can cause a catastrophic failure in mere seconds. Such a failure can cost thousands of dollars to repair. This warning is most often the result of a very low oil level as indicated when checking on the oil dipstick. The engine oil level should be maintained as close to the "full" mark as possible - without exceeding it. Oil should never be allowed to drop below the "low" mark on the dipstick. If the oil level is shown to be between full and low, the light is probably coming on as a result of a faulty oil pump (the oil level should be checked with the vehicle parked on level ground, with the engine OFF). A faulty oil pump is unable to pump the oil with enough pressure to reach all the moving parts of the engine that require lubrication. Without proper lubrication, connected moving parts heat up, expand and seize. Moving parts are expected to move - not be prevented from moving. If your engine shut down, it may be the result of some of the internal parts seizing. Hopefully, this is not the case. Check the oil level and top off as needed to bring the level up and attempt to start the engine and have the vehicle checked by a trusted mechanic. Good luck!
Get an oven thermometer, run the car untill the check light goes on, using a multilayer rag slowly open the radiator cap one notch.If if the cap wiggles loose & no steam comes out , you can fully remove it. Put the thermometer into the liquid coolant , if temp is 180 F (+- 20), the problem is electrical. If steam comes out its a cooling system problem. Use commonsense in doing this. Probably the gague is faulty.
Probable transmission problem check fluid level look for debris in fluid scan check engine light if it's related to the transmission scan transmission side
The car Gods created check engine lights so people don't have to guess at where to start. Get the codes read. Then you'll have a starting point. Waste of time to guess until you do that. Check engine light on Part Ricks Free Auto Repair Advice
You have to find the leak. The Check engine light is probably on for engine over temperature. You will need a scan tool to confirm. Look for a leaking waterpump or thermostat housing on those models.
