It doesn't have any reset hole that I can see , and the only button on it is the power button
FixYa
Ematic Eb104 eBook Reader
Question about Ematic Eb104 eBook Reader
ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
by sharhonda cox on Jan 8, 2014
Add Comment · Flag · Share
April Argo
Level 1 New Friend · Contributor
Andrew Jones answer was correct...
Helpful 0 Not Helpful ·Add Comment ·Flag
M Asish
Level 2 MVP · Expert
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
SOURCE: i have an ematic tablet modle #ewt826bk
Just Google the brand name and the model and use the words "factory Reset"
NOTE: This will erase everything from the tablet and reinstall its operating system to factory default. This is the only way to get passed the password if you forgot it.
1). Make sure the tablet is off.
2). Press the and hold the POWER BUTTON the obediently press and hold the BACK BUTTON.
3). Continue holding BOTH buttons until the Emetic logo appears. The release only the POWER BUTTON continue to hold the BACK BUTTON until the android with open door and menu appears.
4). Select "WIPE DATA/FACTORY RESET"
5). A list of several "NO.." will appear, scowl down and click on the only "YES.."
6). With the "Yes.." Highlighted in a blue bar press the "POWER BUTTON" one time.
7). The system will format and restore the operating system.
8). Select "REBOOT SYSTEM".
9). You should be good to go.
9). You should be good to go!
If you solved this please help me. I have the ematic egq327 stuck in boot loop
