Category moved from Kenmore Oven to Washing Machine
codes tend to be generic.. It is a speed sensor issue. you need a service call.
F7 error code Kenmore washer
The F7 E1 error code indicates a Basket Speed Sensor Fault in the top-load, belt-drive washer (VMW). F7 E1 is displayed when the main control cannot determine the speed of basket-or speed changes too quickly.
May 7, 2014
Press the Pause or Cancel button twice and the Power button once to clear the code. That code is a speed sensing fault. Maybe the washer was overloaded?
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
Hello
you need to clean the filer on the front of the machine , or check the pump for a faulty impeller , a good. Clean of all the draining system would be a great start,
I don't know what the problem might be but if you take off the lower front valance (front of machine below door, 3 screws at bottom edge) Inside the machine there's a packet of information attached to the right side of the enclosure. Inside the packet is a trouble shooting guide that discribes all the codes. Good luck.
After doing some researching I found this solution.
Good Luck, I hope it helps
Please rate me, Thanks
"F/07"
Motor Control Unit Error The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
i read your report heres the site for your codes WhirlpoolDuet Washer ErrorCodes
Topic: WhirlpoolDuet Washer ErrorCodes (Read 5660 times) ...WhirlpoolDuet Washer ErrorCodes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ...appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
F7 = motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Thanks
