Make sure you transducer is sitting level with the bottom of the boat. Follow the transducer cable down the line from where it plugs into your unit. There should be a tag on the transducer that says which model the transducer is. Go into "setup" in your settings and make sure the correct model of transducer is chosen.
SOURCE: rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
SOURCE: Eagle Cuda 168 has no display over 30 feet of water
Try good alakaline batterys(duracell or energizer)alot of those rechargables dont hold amperage and dont stay recharged long!!!! :)
SOURCE: Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
SOURCE: Bottom Line Fishin'Buddy II Fish/Depth Finder user guide/manual?
i have an older fishin buddy 2 bottom line sidefinder i need a manual, a bracket that holds it to the boat and the battery holder / handle i hope you can help me with this my email [email protected]
SOURCE: Problem with Eagle Cuda-168 fish
I NEED A TRANSDUCER FOR AN EAGLE-168.
SOMEONE CONTACT ME. PLEASE..............
[email protected]
