Hardware & Accessories Logo
A
AL Henry Posted on Jul 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need help in programming my utilitech 0192773
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245043
Points
21965
5 Related Answers
Anonymous
  • Posted on Feb 25, 2010
SOURCE: I have a utilitech 0192773 self adjusting timer
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
Anonymous
  • Posted on May 14, 2010
SOURCE: Utilitech Self-Adjusting Wall Timer- #0192773.
Here is the url to the pdf file. You can then magnify your computer screen.
http://www.thencc.com/LS/Instruction/LW60418_Instruction.pdf
Anonymous
  • 3 Answers
  • Posted on Sep 19, 2010
SOURCE: Programming Utilitech Item # 0192773
Go through the normal setup. Year, month, day, time, DST and the location (north, center, south).
Hit program and make sure all events are clear. Program the first (ON) event, press the TIME button and press /- (with the hour segment blinking) until you see the Sun/Moon symbol indicating the sunset time. Press PROG and program the (OFF) event. Press the /- buttons until you see the Sun/Moon symbol indicating the sunrise time.
Hitting resume clears events if you accidentally entered them.
Make sure you display shows AUTO and you're good to go.
A
Anonymous
  • Posted on Oct 05, 2010
SOURCE: Need online instructions for Utilitech
Utilitech self-adjusting wall timer # 0192773
A
Anonymous
  • Posted on Dec 09, 2010
SOURCE: Only 2 black wires on current switch - Utilitech 0192773 has 4
Webpage explains wiring and has large print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Porch light timer switch problem
0192773 is single-pole only.
I think you have wires reversed or attached incorrectly:
http://waterheatertimer.org/How-to-wire-timers.html
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Bought a Utilitech #0192773 to replace an older and non-working Intermatic SS7 series. The Intermatic had a black wire connected to hot, and a blue wire connected to neutral, and a red wire was capped off...
Utilitec 0192773 replaces single-pole switch and will not work for 3-way applications.
Open following link for clear wiring and programming steps for Utilitec 0192773
Utilitec can also be tricky to program if you are setting up astro dawn-dusk function.
For others finding this thread, same wiring applies to in-wall programmable timers by GE, Woods, Swilight, Sylvania, Tork, Hagar, UPM, Leviton, Grasslin, Wattstopper, Westek, and Intermatic analog timers. Intermatic battery-operated, Brinks and Aube timers are wired differently since they also work for 3-way applications.
How do you set a utilitech timer
Which Utilitec timer do you have?
Following page has instructions for 0192773, with links to 0155671, 0144506, and 014124 programmable timers:
Add a comment with your timer ID and I will help more.
If your timer is not shown on link above, add a comment and describe your timer.
I have extensive files on timers.
Utilitech Self-Adjusting Wall Timer- #0192773. Unable to program timer. The instructions are so small it is hard to read them
Utilitec 0192773 is also listed as LW60419
1) Has optional daylight savings plus dawn to dusk programming
2) Electrical wiring must be connected in order to program timer. This is because timer is powered by electric circuit (instead of battery).
3) Program choices:
-Individual days MO TU WE etc
-All 7 days of week
-Weekdays
-Weekends
4) Large manual + wiring tips:images load slow with dial-up
5) Enlarged manual
-Click on image to enlarge
-For more size, hold down Ctrl key on keyboard and use scroll-wheel on mouse
5helpful
1helpful
3answers
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
