When trying to use, shutter closes and sticks so that pic cannot be seen
SOURCE: digimax i6 pmp SHUTTER problems!!!
Solution worked flawlessly. 8 little screws removed (4 on the botton on the side - two on each side of the power charger interface assembly; 2 holding the verticle plastic covering on the side of the camera, and two additional screws underdeath the plastic covering just removed) was all that was needed to create enough separation in the unit to free the protective cover for the lense. The protective cover for the lense now opens and closes as it should when power is enabled/disabled. Thanks for the post, really paid off.
SOURCE: the shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
SOURCE: The shutter is sticking half way
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
SOURCE: iPhone camera shutter won't open! - 3Gs
I have had the same problem. I backed up all photos/videos from the phone and then deleted them, then rebooted the phone (off/on). The camera functioned after that. Then I restored the photos to the phone.
SOURCE: Kodak C743 shutter
Had same problem. If the batteries are good, simply take them out and reinstall them. Worked for me.
