SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
SOURCE: new lamp replaced but yellow lamp light is flashing
Go to this Website they will list all Parts/boards and everything you need for this TV
WEBSITE:
Encompass Parts Distrubtion 1-800-638-3328
SOURCE: I have a Mitsubishi 73"
I'm sorry, but your looking at an Optical Block Assembly which also includes the DM module. Latest figures are approximately $650.00 to replace. I would have called a service tech out to properly diagnose the problem first. Please let me know if you have any other questions.
SOURCE: I have a Mitsubishi 73" TV model number WD-73735.
Try replacing the thermal sensor. Located behind lamp in lamp housing shroud.
