Heating & Cooling Logo
Beverly Risley Posted on Jul 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My spt portable swamp cooler fan stopped working. I hear water pumping led panel shows fan on but not blowing If fan motor out can it be fixed or do i to replace it?
Steve Pack
Level 3:
  • Heating & Co... Master 7,125 Answers
  • Posted on Jul 19, 2018
Steve Pack
Level 3:
Answers
7125
Questions
Helped
2273403
Points
27938
You have to replace it about $60-$75 for motor.
5 Related Answers
Anonymous
  • Posted on Jul 26, 2008
SOURCE: Shouldn't it be cooler?
Just found at least one problem with mine. I pulled off the back screen and then pulled off the back cover by undoing the two screws at the top. There is a pad in there that rotates through the water reservoir. If this pad doesn't get wet, you won't get any cooling. My pad was bone dry. Turns out the wire for the motor that rotates the pad was disconnected from the front control panel. I reconnected the wire and now the pad rotates through the water reservoir. We'll see how this works.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 11, 2009
SOURCE: water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
Anonymous
  • 340 Answers
  • Posted on Jun 26, 2009
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Anonymous
  • 10865 Answers
  • Posted on Sep 02, 2010
SOURCE: I have a Westwind Convair
hi.
here is the company contact info. http://www.cylex-usa.com/company/convair-cooler-corporation-5048927.html
call them to order.
Anonymous
  • Posted on Sep 03, 2010
SOURCE: Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
1helpful
Where may I purchase parts for my apartment Swamp Evaporative Air Cooler
Question edited for clarity.
Question moved from Washing Machines.
First link is the maker, also Sylvane seem to sell the same thing under a different badge. You need the NUMERICAL model number to order parts.
https://www.google.com/search?q=SPT+evaporative+cooler+parts
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
2answers
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
4helpful
Swamp cooler is not blowing cold air. Water is
3helpful
2answers
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
My portable air conditioner has stopped pumping water to the tank
this would be a swamp cooler.if you have water in it and its not pumping.its going tobe the pump but i would see if the pump is getting voltage first before i bought a new pump.where doyou live that your worried about a cooler?
4helpful
3answers
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
2helpful
Top Heating & Cooling Experts
Paul Carew
john h
