SOURCE: "grease" stains on whites and light colored clothes
Run A Load With No Clothes And Put some Goo Gone In There. May Help.
SOURCE: My Whirlpool duet sport machine
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
IT'S NOT A STAIN, looks like you bleached the color out by accident, lots of things other than bleach will take the color out of fabrics.
As a general rule when cleaning boot, you only want to use products specifically designed for boot fabric. Avoid using a product designed for cleaning leather. It's also important to do a patch test before cleaning any fabric to make sure the color or integrity of the fabric won't be damaged. To do this, apply your cleaning product to an area of the shoe or boot that doesn't show to see what the effect will be.Here's how to clean shoes and boots at home.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Instructions
Things You'll Need:
Prepare Your boot for Cleaning
Start by gently rubbing the surface of your shoe or boot with a soft, dry washcloth. This helps to restore the surface of your shoe.
Remove Dry and Ground In Stains.
Use your pencil eraser to rub any areas of dry staining. The eraser helps to life out any dried dirt and debris from beneath the surface of the shoe.
Smooth the Surface of Your Shoe.
Using your metal brush, to brush the surface of your shoe or boot using a circular motion. This helps to smooth the surface that's been roughened by using the eraser. It's also good for removing scuff marks from shoes
If you are happy with my answer please vote four thumbs up. Thank you
