SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something. I have done it a number of times - usually after a paper jam.
SOURCE: konica minolta is getting error c2557, before this it was saying
c-2557 code has to do with you black toner bottle.
how handy are you?
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: how can u resolve all lights blinking on minolta
Unplug from PC, unplug from wall, leave unplugged for say 5 mins, and then plug back into the Wall, then, reboot PC, then plug into PC. Now should be OK. If NOT please use the manual below to troubleshoot whats wrong.
http://kmbs.konicaminolta.us/content/products/models/magicolor1600W.html
SOURCE: i have fetal error code 08H,14H &15H in
When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
