Electronics - Others Logo
Geoffrey Lines Posted on Jul 16, 2018
I want to display data from my USB Memory stick
James M Knox
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Mar 05, 2019
James M Knox
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
13548
Points
53
Sorry, but that's not very specific.
Most USB memory sticks (aka thumbdrives) are "plug-and-play." Meaning you stick them in a USB host socket on a PC (MAC or Windows or Linux, for example) and they automatically get configured and are available for use - just as you would use a computer hard drive.
If that is not happening, then there is a good possibility that the stick is not properly formatted. If it is recognized, but you cannot access the data, then you may need to run the FORMAT utility on your computer. Be aware that this will erase any data currently on the stick.
If you KNOW that you have data on the stick, and it is important to you, then there are data recovery companies that will do their best to access the data (for a fee).
5 Related Answers
AvioriX
ExpressFiX
  • 691 Answers
  • Posted on Mar 01, 2008
SOURCE: USB Memory Stick
You may link using tiny wire solder it as bridge. It will work if you solder accordingly. If you need further assistance please post the close shot picture of the broken area. Good Luck
Anonymous
  • 7 Answers
  • Posted on Jun 10, 2008
SOURCE: memory sticks
First you have to make sure there is enough room on the memory stick. Plug in the USB stick and open My Computer. You should see a "removable device" on E or F. That is your memory stick. Right click and select properties. It will tell you how much free spce there is. Now check the size of the powerpoint presentation the same way: Navigate to it and right-click.
If there is enough free space, you're almost there. Right-click on the powerpoint file (ending in .ppt) and select copy. Then go back to my computer and open the F:\Removable device icon. Once inside the device, right-click and hit paste. You should see the .ppt file being copied onto the memory stick. When it is finished, right-click the F device again and hit eject.
Anonymous
  • Posted on Mar 08, 2009
SOURCE: Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
Anonymous
  • 256 Answers
  • Posted on May 30, 2009
SOURCE: I need to know the steps to save data onto usb memory stick from accounting program
I suggest that you save your data with Simply Accounting and know where you save it. In window explorer, find the file you saved and copy it to the USB memory stick. You should see the USB memory stick as another drive in Windows Explorer. After the copy is complete, Click the USB memory stick and you should see the file. This way, the copy (back up) is confirmed.
Anonymous
  • 115 Answers
  • Posted on Sep 11, 2010
SOURCE: display reads usb mode mass storage usb memory
it means that your camera is set to have the memorystick detected when connected to a computer. ( camera have options to have memorystick or internal memory detected by computer)
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
2answers
Can't delete data off USB stick
SO YOUR OFF USB STICK IS NOT DELETING YOUR MEMORY CARD MUST HAVE DOING SOME OPERATIONS PRESS CTRL+ALT+DELETE THE DALOG BOX WILL APPEAR GO TO PROSSESS AND STOP THAT PROCESS
Sony memory stick is damaged n i wants to recover my data from memory card is it possible?
once USB is damage there is no way to retrieve data from it. but you can try to get all data using DOS command.
I have lost the instruction to the memory stick and have no idea how to use it. The password etc is blanked out when you plug it in
im not sure what you wat to do or are referring to if you are try to remove the password download dr freeware i have never used or had to use it it reads like it can remove passwords from any usb drives and if you are trying to use it but dont the basics
insert this drive into a usb slot
click start click on my computer you should see your usb drive or
click start all programs accessories open windows explorer navigate to your usb memory stick then go to the information you want to back up select the information right click select copy then back to memory stick select then right click select paste
or select the imformation hold the cursor on then drag it to the memory stick and drop it into it
or select the imformation right click and send to the memory stick
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps you
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
How would you save a story on micro word with a memory stick
Hi Friend,
Please follow the gevin instructions-
1-Insurt the memory stick in USB port of the CPU (USB port available in front and backside of the system)
Note-mainly system detect memort stick automaticaly,some time not detect at that condition go to tme my computer maange option(after right click of the my computer you will be able to see the manage option and go to the device maange and update the USB driver)
2- Copy the data (micro word)
3-Past the data into pen drive (memory stick)
4-disconnect the memory stick
Thanks,
How to remove usb write protection with notebook
Are you having trouble writing to a USB memory stick and you get a message that the USB memory stick is write protected?
Some memory sticks have a small slide switch which you can select to write protect the data on the USB memory stick.
1helpful
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
