SOURCE: Feeder problem
posibilities r ink,rollers,catridge head etc so loos n check these things if there iun place
SOURCE: Manual paper handling
Should be able to. Change the default paper tray in printer to the manual tray.
Rgd
S88
SOURCE: living in pennsylvania, when should I take my
Birds will instinctively know when to fly south, however you are correct in assuming that they may stick around longer if a food source is provided. This could be dangerous for some species of birds. The general rule of thumb for your area is that whenever the highest temperature of the day is less than 60 degrees Fahrenheit you should take down the bird feeder.
SOURCE: when should one quit feeding hummingbirds in Northern MN
when you don't see them anymore. prob. by first frost
SOURCE: feeding fast p23-dhv can not open the back
If it were feeding too fast, there'd be gaps between lines. I suspect it's slipping and not feeding. In that case, the gear that's turned by a lever is missing teeth, the lever is rounded, or the spring that holds the lever down against the gear is missing. All speculation on my part.. I didn't look the item up to see if it works that way.
