Cycling Logo
Dan Symes Posted on Jul 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have no clue how to tighten the chain on a Moongoose XR 15 mountain bike
Jone Edword
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jul 30, 2020
Jone Edword
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
Helped
1459
Points
7
In this time period, you already learned how to solve this.
Anyway, if not then check this
https://papasroadtrip.com/how-to-tighten-a-bike-chain/
Donald Ayers-Marsh
Level 3:
  • Mountain Master 1,389 Answers
  • Posted on Jul 09, 2018
Donald Ayers-Marsh
Mountain Master
Level 3:
Answers
1389
Questions
0
Helped
559466
Points
6679
As noted, the derailleur takes up chain slack. If not doing so may need new derailleur, may have mounted it incorrectly, or too long a chain installed. If chain is skipping under pressure that is due to wear, not chain tightness.
Bill Boyd
Level 3:
Top Expert:
  • Mountain Master 53,816 Answers
Bill Boyd
Mountain Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11933508
Points
172802
If you have gears , then the spring loaded idler or gear jump idler will keep the correct tension
if you have direct gear to gear then pull the wheel back in the slots
john h
Level 3:
Top Expert:
  • Mountain Master 29,494 Answers
john h
Mountain Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7551164
Points
193449
Loosen rear tire pull back and tighten when chain slack is removed
How do I tighten the chain on my son's 24 Next PX 4.0 Boys' Mountain Bike? It seems very loose
Hi Mitchell:
I looked at some pix of this bike and they showed a shifter. As long as the springs on the shifter mechanism are moving it as intended, the chain tension should be fine.
It's a good idea to occasionally clean the gear change assemble with a spray solvent, wipe it down, and then lightly oil it.
YES SOMEONE STOLE THE SEAT AND POLE TO MY MOONGOOSE SPIRE BIKE AND I NEED TO KNOW WHERE I CAN BUY ANOTHER ONE
measure the diameter of the hole in the frame where the seat post goes. Get online and order one. They vary in size so get a precise measurement.
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Trying to assemble mongoose back tire and chain
I am sorry I could not find a manual for your Mongoose.
I will suggest you go to the following website
http://www.youtube.com/watch?v=2j1gSwhsVN8
You can find numerous videos for your bike repair.
in Youtube
Bud
On mountain bike the chain or peddles seem to slip or click goning up a hill. Is it the chain slipping or worn gear?
It sounds like your chain is loose. Flip the bike over and loosen up the nuts on the back tire and tighten the nuts as you are pulling the rim back making the chain as tight as you can. You might need someone to help you pull as you tighten the nuts.
Aug 26, 2011 • Cycling
I need to find a part # for a chain ring for a Mongoose XR-75 mountain bike
Mongoose didn't make the chainring. They're generic (like most bike parts) and have many substitutes. Determine the parameters and then go looking for one that fits.
http://www.sheldonbrown.com/gloss_bo-z.html
Other parts may also be worn, like the chain.
http://www.sheldonbrown.com/chains.html
2helpful
How do you tighten the chain on a Mongoose 75 mountain bike?
there is a spring tesioner but probally need to take a link or two out of chain
3helpful
Mongoose tactic mountain bike / loose crank on chain side. How to tighten.Chain ring moves with it. Makes clicking noise.
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
2helpful
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
2helpful
How do i tighten my cam chain on my 03 xr 250
Your bike has an automatic cam chain tensioner. There is no "adjustment". A spring supplies the tension and I will bet the spring is broken. It is possible the fiber band that is the tensioner has broken but that seldom happens.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Top Mountain Cycling Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
