SOURCE: my texas instruments ti-30Xa doesn't turn on!
It has a solar battery. It has to be in the light, either sun light or artificial light to operate. HOWEVER, if the battery is shot, it must be replaced. Take your calculator to any radio shack store and ask them to test the battery for you. If it is no good, they will be able to replace it for a fee.
SOURCE: texas instruments TI 38 PLUS USAGE
Here is the link to free downloads of TI graphing calculator's guides.
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=17
Enjoy
Hope it helps
SOURCE: Texas instruments TI-83 Plus won't turn on
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution:
The resets described in these troubleshooting steps will cause a loss of
applications, programs and data. If at all possible please create a backup using TI Connect™ first.
Reinstalling the OS fot the TI84Plus
How
do I correct the Error Waiting...Please Install Calculator SoftwareNow
message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The
most common cause of a transfer being interrupted is updating
the operating system on a calculator with low batteries. Users will need
to use the TI Connectivity cable and the TI Connect to send
the operating system to the calculator. Make sure to have the
latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the
message "Error! Press any key to turn unit off. Then turn unit back on."
appears on the graphing calculator, quickly, remove one battery from the
calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at [email protected] or www.ti.com/calc.
SOURCE: my texas instruments ti-86 is dark all the time,
After changing the batteries the calculator is restored to
factory defaults, but the screen contrast may change. The screen may be
too light to see anything or., as in your case too dark.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
To darken screen
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
