SOURCE: can't find owner's manual. need to use my kirby g4
Remove power head and bag from motor install pig nose attachment on front where powerhead goes install hose on back where bag attaches put inflator tool on hose
SOURCE: How to use the tire pump tool on the quickpump.
I have the instructions if you send me your e-mail address i will send them to you.
SOURCE: what is an indoor solution to finding the leak in
Two ways, one is to move around it slowly using your cheek (face that is). It is sensitive and will pick up the leak easily, and then just mark it with a marker. The other, although a little messy, but extremely effective is to use your bath tub. Best of luck.
SOURCE: Want to blow air out to inflate mattress
You need to remove the main head with the brushes from the front and install the safety cup. The remove the bag by unclipping from the top and disconnecting the boot end from the bottom with an outwards twist. Now attach the hose to the exposed outlet; attached the thin nozzel designed for inflating to the hose and switch on - you will feel air being expelled from the hose.
Air, which normally contains dirt and dust because you're hoovering is blown into the bag, but now with the bag removed; the air is blown into your hose, through the attachment and into what ever needs inflating.
For a good visual set of instructions click on the following link and scroll down to the second set of instructions :
How to change hoover to a blower
