Please check this thread from answersbag.com
"1. Insert the DVD with Region Code which will not play.
2. Press 0000 on the remote and a new screen should appear showing Region Code for the LG V271 (as Region 4).
3. Select new region code as 0.
4. Press Pause to exit the screen and your LG V271 should now be region free."
If you want to make your players region free, you can go to VideoHelp forum and then go to the DVD hack section. All you need to do is to type in a model of your DVD player and then search for the hack exclusively for your model.
You can also use some tools to remove region code such as Leawo Blu-ray Copy
SOURCE: Multi region code for my DVD player
open draw
press '0' 3 times
press which region (Eg 0 for multi)
press pause
and whola!!!
SOURCE: Can I make my LG RH4820W HDD/DVD recorder multi region?
1 Power on the DVD recorder
2 Press "open"
3 Press "0000000" on the remote control slowly
4 Congratulations' will display on the screen if setup was successful.
5 Press "enter", then finish
SOURCE: How can i make my lg DP481B portable dvd player
Testimonial: "thank you so much. This was a delightful surprise and much appreciated!"
SOURCE: have a DV490H LG DVD player that is set to region
HELLO
I found this hack on www.videohelp.com - give it a try!
* 1. Door Tray Open
* 2. Push "000" Button
* 3. Region Code: 0
* 4. Press "Pause" Button
ALL THE BEST :-)
SOURCE: Multi Region Code LG DV380
Open Tray
Press 0 three times and when region menu appears select 0 then press pause
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
