Should I make him complete what he started?
This is not really the site for this topic. could try mums net https://www.mumsnet.com/Talk. children go through stages, they also see things different from adults. making him do something he doesn't want to do can harm his development. you need to find out more, and the reason he doesn't want to go. it could be something as simple as he want to spend time with you. or something has changed a what he is doing there, it can be a number of things. have had 4 children myself, forcing him will just turn it into you dont want him there in his eyes. or its to hard for him and you are wanting to make him fail. filing at something is a good thing, knowing how to handle failing and being able to overcome this is good for his future. even einstein failed at things and look what he became. hope this help but speak with mums net they are a group that may be able to help you now and in the future.
SOURCE: brake light remains on on the Honda Accord 1995
Made sure hand brake depressed all the way.Checked brake fluid level?
SOURCE: One day my son drove his 2000 Blazer to school
its very possible and it could be the soilnoid on the starter
SOURCE: My son has had three
you need to test the ignition wire on the solenoid the small one when you turn the key to start the car if the test light lights and the starter does not kick in yes its # 4 while holding the key in start position bang on the starter with a hammer it might start its a common problem with fords bad starter rebuilds and a lot of heat under the car but if you have no test light lit while turning the key then you have another problem like ignition switch or nuetral safety switch hope this helps
SOURCE: Kia sedona 2.9 5 years old completely dead no warning. Would it be battery?
check the voltage of your battery if is low charge and start.the engine and check if the alternator need produce 13 -15volts aprox.and make sure the battery hold the juice if all is ok you have in your car a short to ground if this is your problem but maybe not post me and i will be explain an eassy way to fix that problem.good lock.
SOURCE: I have a 2006 Chrysler town and Country... this
You need to charge it for at least 24 hours :] hope I helped
The Colgate Motion Toothbrush is completely safe for children over the age of three. Since your son is only two, it's important that you supervise him while he uses this toothbrush.
