Take the nobs off and spray the nob while the sft is pushed in with some deep penetrating oil do this on all and leave to soak, and then one by one try and turn them back and forth and spray a bit more. should loosen them up ( no gas on while doing this) brass fittings bond with dust and different changes in heat and cold. just needs them cleaning out. if you can have it standing with the controls up in the air this will help oil get though to all parts in the valve.
SOURCE: Looking for manual for Coleman Roadtrip Grill LXE
http://www.coleman.com/coleman/images/pdf/9949-750.pdf
SOURCE: regulator pressure for a Coleman Roadtrip
Have you tried COLEMAN SPARES old chum?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: low flame roadtrip grill, when both sides are on at the same time
could be blocked burners of blocked orfice , or reg on tank , which all give low pressure
SOURCE: My Coleman roadtrip cooks way
If you're cooking at the lowest setting and the flames are to high, you will need to replace the gas control valve for the burners. Coleman still stocks some parts for your model. Appliance Factory Parts carries a wider selection of parts. http://www.appliancefactoryparts.com/
I hope this helps. Happy Grilling!!
SOURCE: I have a coleman roadtrip
There is no repair. The canister holder/control valve will have to be replaced. You can contact Weber directly at 800-446-1071. If they don't have it try Appliance Factory Parts http://www.appliancefactoryparts.com/ They have a large selection of replacement parts for all makes & model grills.
Good luck and Happy Grilling!!
