I have a bizhub 224e printer it was working fine but suddenly it starts to print blank pages even when i am coping i change the jum and developing unit and i am have the same problem what can i do to solve this problem
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
SOURCE: hp laserjet 1300 prints extra blank page
Before you get a better answer to me , I hope you would have told us if you are the first person that used it so that we can know if this problem started from the initial point or at the middle time of using the printer
1) Did you add additional memory to the Printer?, if Yes remove and try back.
2) Try you use this printer in another PC
3) Look for HP1300 printer software.
4) It may be a mechanism/paper carriage error which can not be corrected by software unless you change mechanism/paper carriage.
SOURCE: Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
SOURCE: Printer prints blank pages from notepad, word, and excel.
Hi tim8094
Obviously there is nothing wrong with the printer, because you are able to print from the Internet.
Before attempting to print from word, excel etc, make sure you have the correct printer selected (check it through FILE MENU -> PRINT ->PROPERTIES)
Do a print test by typing just couple of words -may be in different color-
Best of luck
luciana44
SOURCE: Canon jP 1500 is printing blank pages
Try a deep clean, sounds like a blockage but odd all at once. it could be possible that cartriges are a faulty batch, ive experienced many times but not all at once. hope this helped jay.
