SOURCE: Tissot T-Touch-Works fine until just about the end of the warranty
I suggest writing to Tissot in both your home country and in the head office in Switzerland. Use both email and paper letters. If you can provide documentation of the attempted fixes that will really help your case. Since you had a history of problems you have every right to ask them to stand behind their product. Perhaps there is a new warranty on the replacement movement, for example. You have nothing to lose except a bit of time, paper and postage. You could even ask your dealer to back you up with this -- he or she will still get paid for the work if Tissot agrees to extend the warranty.
SOURCE: tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
SOURCE: Tissot wrist watch goingin reverse since new battery fitted
It sounds like the battery might be in backwards. They do
have polarity,...it DOES matter how it goes in. Try opening it, and
flip the battery to see if that helps.
Mark
SOURCE: Hi guys,
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Thank you for the response. Fortunately I was able to identify the problem. The center button when pushed doesn't fully return and still touching the movement's contact thus in this position the watch becomes erratic and the digital's seconds starts to run fast after a while. Hope this helps others having the same problem.
