SOURCE: Konica Minolta 250 Bizhub scanning Operations
what u need to scan to emails is the email smtp ip address.
just put the ip smtp address in the network setting>smtp address
and try to ping from ur B250, if the result is OK, then u have the connection. go to Utility/Counter>user setting>one touch to register
the user address, then scan it, u should be getting the scanned file in ur inbox.
SOURCE: Saving scanned docs. in 1 file with Canon PIXMA MX310
Configure the scan to file to save as PDF file
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
SOURCE: HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
