Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
SOURCE: Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
SOURCE: Beeping Problem
Hi, this is a high temperature beep and the reason for this is that the thermostat has become unstable. it is unable to read the temp at this time. replacing the thermostat will fix this issue.
SOURCE: Notification alert for calendar items on Samsung i780
Hi there!
Try to click the bell icon when you set your alarm and see if you have checked the box for "play sound".
Also, verify if your volume is up and not in "Off" mode.
Also, go to Settings, click Sounds and Notifications. Verify if you were able to check the "Enable sounds for programs" box and make sure the notifications box is checked.
And on the notifications tab select "Reminders" from the drop down menu for "Event" and ensure that "Play sound" and "repeat" are checked.
Hope this will solve your problem!
SOURCE: my bosch dishwasher beeps everytime we close the door.
Better switch of till you are ready with full load. Otherwise you have to trace the beeper and disconnect it.
SOURCE: My whirlpool WBM35LW refrigerator now beeps
Throw it out and don't buy Whirlpool again. I had the same fridge and it was doing the same thing and would of cost heaps to fix it.
