We had a lightening storm, and since then the tv has not worked.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
SOURCE: TV always in standby mode and can't display channel. Need press many times
Go to Badcaps forum online
