I don't know if i have changed any settings but i have reset my calculator as it used to give the answer as a surd and no longer does.
SOURCE: I have a Casio fx-300ES
I understand your frustration, but believe me there is nothing wrong with your calculator. You just have to invest a minimum amount of time to familiarize yourself with its powerful capabilities.
No matter. Your calculator has to input output modes. MathIO and LineIO. MthIO is new and it allows you to enter expressions as if you were doing it by hand (like in textbooks). LineIO is the old way.
In MthIO your displayed results are fractions or radicals (roots) or a mixture of the two. BUT if the screen cannot fit the fraction or radical form, the calculator will use decimal to display the result.
In LineIO you only have decimals results.
To get fraction or radical results configure the calculator to use MthIO. In this mode, if you want a result converted to decimal, just press the SD key. It will toggle between the two.
To set MthIO, press [SHIFT][MODE] and select [1:MthIO]
To set LineIO, press [SHIFT][MODE] and select [2:LineIO]
SOURCE: I have a casio fx-300ES
Hi suebie50
Have a great day.
To change the output to decimal form, you can do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO).
The answer will show in decimal format.
You can also use this website whenever you have further questions in using you calculator:
http://www.generalmanual.com/Calculators/Casio-FX-300ES-Scientific-Financial-Calculator.htm
Hope it helps.
Thank you for using fixya.
To convert a single answer from symbolic to decimal, press the S--D key (just above the DEL key). To have all answers come out in decimal format, press SHIFT MODE 2 to switch to the LineIO mode.
SOURCE: on my casio fx-82au plus calculator it won't
the emulator and also kind 'VivaVideo' right into the search bar. VivaVideo Download You could download the app from the Google Play Store.
Change the output display to MathIO. You may be able to display square roots only: so no cube roots, nor fourth...
