SOURCE: How to install flange conversion kit for 96 300tdi Land Rover Disco
does the kit come with gear or just flange ?
SOURCE: Removing Prop
There should be a retainer nut accessible at the rear of the prop (in the center of the prop. Remove this and the prop should slide off.
SOURCE: Can't understand how to remove tha rear prop shaft
Ya sure I'll tell when i find out some other way but the answer is gonna cost you $15.99 hows that for an answer. Why would I tell you for free if you want to be payed for it so do I. Delete me as a member.
SOURCE: front prop shaft on a 2004 polaris Atv
the best way to remove it by using a air chiping gun
if you do not have one a punch and hammer will work
SOURCE: How do remove the old rotor from the shaft
Here are instructions
www.rctoys.com/.../install-new-palmsize-mini-heli-main-rotor-blade-tail-propeller
