5y5 code on Suzuki grand vitara 2001
The anti-theft feature is intended to discourage
theft or the audio system by preventing
the system from operating when it
is moved to a different vehicle.
This feature works by allowing you to enter
a Personal Identification Number (PIN).
When the audio system is disconnected
from its power source, such as when the
audio system is removed or the battery is
disconnected, the system will not operate
again unless the PIN is reentered.
On Page 4-52, it goes on to say:
Setting the Anti-Theft Function
1) Turn off the power by pressing the
power on/off knob (1).
66J118
2) Press the power on/off knob (1) while
pressing and holding the track up button
(2). The "ENTRY 0000" will blink
and the audio system enter PIN-input
mode.
NOTE:
Establish your PIN by combining numbers
from 1 to 6 into any 4-digit number. If you
forget your PIN, when you remove the battery
for repair etc., you will no longer be
able to operate the audio system.
66J117
3) Input the four digit PIN using preset buttons
1 to 6.
66J118
4) After you enter your four digit PIN, the
display will return to "0000".
66J117
5) Input the same 4-digit number you previously
entered.
66J120
6) The power of the audio system will turn
off.
NOTE:
Write down your PIN for the future use.
Canceling Your Established PIN
Setting
This operation is to be done when you
want to cancel the anti-theft function or
change your PIN.
66J121
(2). The "DELETE 0000" will blink
and the audio system will enter the cancel
mode.
& finally, Page 4-53 wraps it up:
INSTRUMENT PANEL
66J124
3) Input your PIN. The power of the audio
system will turn off and your PIN will be
deleted.
To change your PIN, first delete your
current PIN, then set a new one.
Confirming Your Personal Identification
Number (PIN)
When the main power source is disconnected
such as when you exchange your
battery, etc, you will have to confirm your
PIN to be able to use the audio system.
To confirm your PIN:
66J122
1) Turn the ignition switch to the "ACC"
position.
66J125
2) Input your PIN.
If the PIN that you input matches the
registered PIN, the power of the audio
system will turn off, and you will be able
AND THIS IS AN IMPORTANT NOTE:
• If you input your PIN incorrectly, "----" will
be displayed and the anti-theft function
lock mode is entered. If you enter an
incorrect PIN fewer than 6 times, the
locking time will be for 15 seconds; if you
enter an incorrect PIN more than 6
times, the locking time will be for 15 minutes.
• If you forget your PIN and enter a wrong
PIN, you can not perform any further
operation.
