SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
SOURCE: Keyboard letters wont work but only top row Of numbers
On a notebook computer, there is a FN key that when pressed with the appropriate special function key will disable the normal keyboard and enable the alternate letters (printed in a different color) on your keyboard.
Unfortunately, I can't remember which special function key that is--but the icon on it should give you a clue.
SOURCE: i have samsang s5233w. i
To connect in a wi-fi network there is an authentication password that are only for authorized body.
To access to password and become an authorized body to access without permission called Hacking witch is illegal so get the password then access otherwise use free access.
thanks
SOURCE: TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
