SOURCE: documents in single space print in double space
There may be a dip switch somewhere on the printer which enables/disables the extra linefeed. If both CR (carriage return) & LF (linefeed) are both enabled, you will get the double-spacing. In years past, I've run a few different Epson dot matrix printers, and seems like they had such a dip switch. Also, on the software end, you may be able to disable either CR or LF- check in your printer driver software.
SOURCE: Trying to type and single space
You can change this by adjusting the line spacing option.
You are talking while typing wright.
You can select the whole document by Ctrl+A.
Right click & select the paragraph option.
You can find spacing & line spacing.
In the line spacing select the numbers as you like.
Its better to use it as 1.5.
And click on ok.
Good Luck.
Live, Love, Laugh.
SOURCE: jagged lines in draft mode
hi, it sounds like the head needs alignment. nLook in the manual, follow the proceedure outlined there and the problem should disappear
SOURCE: I want single spaces between sentences. How do I
You have to set thet in your word processing program.
SOURCE: text is printed over itself several times
Remove both the cartridges and clean the nozzle with tissue paper and install it again.Just try with cleaning the cartridges and also I suggest if it gives the same print out just replace the cartridge.
Have a nice day and do not forget to rate please...!
These drafting tables are really fancy. The tables are made from hardwood and the surface from fiberesin. They come with lots of features. You can buy a table with drawers, a keyboard tray, wire organization, and more. There is plenty of space for a computer and multiple documents.
