SOURCE: In my Hampton Bays ceiling
Yws it is possible.Check on the fan before changing anything, there should be a maximum wattage sticker. Do not go any bringter than the max, it is there for a reason. If your plans are to install incondesent light system, be aware. that, bulb puts out much more heat,
SOURCE: fluro tube
fluro tubes are rated in watts and they are connected to the length of the tube. ie 20 watt 20 inches---30watt 36 inches and 40 watt 48 inches. Some makers have a triclor fluro that have a higher lumens value but the wattage will be the same.. You will have to compare tubes in the lighting shop.
In North-America and Europe the three most major brands are General Electric, Phillips and Sylvania. They actually make the same fluorescent tube with different brand names.
