I had Android LG phone , service with straight talk ,I brought my own phone from At&T and wanted to upgrade it .So after 2 day I finally got it activated ,the 3rd day I finally got my old Number that I wanted to keep to start with ,now that being said I need to ask how don I retrieve all my contacts to my new phone,which is LG v 20 .Then the 2nd question is how Do I sync phone to computer so I can share my photos.
Actually, you can directly transfer contacts from your old LG phone to the new LG v20 if you have both in hands. First connect both of them to computer via usb cables. Here you need a pro Phone Transfer tool to help you do the contacts transfer between them. Mobile Phone Transfer Transfer Data between Mobile Phones Easily
Gihosoft Mobile Phone transfer- a professional data backup and restore software, which can not only help you backup contacts, SMS, call logs, calendar, photos, videos, music on LG, but also enables you to restore backup sessions whenever you need. It supports all LG smart phones, including LG Tribute HD, LG V20, LG Phoenix 2, LG Stylo 2, LG G6, LG X power, LG Rebel LTE, LG K7 LTE, LG V10, LG G5, LG G4, LG G3 etc. As for how it works, please refer to the following instructions.
LG Backup How to Backup and Restore LG V20 G6 G5
Here, this Samsung Sync Software can easily make it within simple clicks!
With this software, you are totally free to import or export anything from LG phone to the computer, including photo,music. This LG Sync Software make it as easy as pie to sync LG to the computer. Also, it allows you to sync Samsung either via USB or via Wifi.
To start with, open the installed software on the computer and then you will see an interface where you are offered two options to connect your Samsung device. Choose the mode of Connect via USB or Connect via Wifi as needed. Then this software will detect the device and show you the main interface as pictured in the below.
As you can see now, all the file folders are arranged on the top panel. You can then enter the different tabs to preview more detailed file information. While previewing, you can select the files you want to sync from Samsung to the computer by ticking them out. Then click on Export option to begin the Samsung sync process.
And if you want to import files from the computer, just click on Import option and navigate to the files you want to import. Finally, click OK option to begin the file transfer from the computer to your Samsung devices!
Now here's the guide:
How to Sync Samsung Phone to Computer
Top notch Samsung Sync Software
The most common way to transfer photos between Android phone and computer is to copy and paste the files. This method can be completed with one USB cable easily. You just need to establish a connection between your Android phone and computer and once the computer detect your phone, you will be able to move the files from/to computer without any hassle.
The methods mentioned above are doubtlessly able to transfer photos between Android phone and computer but you can perform the moving process more effortlessly- make use of a professional assistant software. And here I want to recommend this one for all you Android users: MobiKin Assistant for Android (Windows & Mac).
Step 1. First of all, connect your Android phone to your PC via USB cable and then run the program. If you have installed the USB driver before, the software can recognize your phone quickly. If you didn't finish this, you may have to follow the steps to install the USB driver first before you move on.
Step 2. Click the category Photo on top of the window and you will see the brief information on the left panel. Then click Phone Gallery to preview the photos stored on your Android phone. Tick what you want to transfer and hit Export to copy these photos to your computer. Besides, you can also drag some photos from your PC to your Android photo by clicking Import.
Now you have successfully managed to transfer photos between your LG cell phone and computer.
For more info visit:
How to Transfer Photos Between Android Phone and Computer
SOURCE: flashing an at&t lg to straight talk service
You can Not do either.
You can't change an imei. and straighttalk will not allow another carriers phone to be used on their services.
Straight talk only uses versions towers. The rest of the company is Tracfone. Tracfone doesn't play well with othere
SOURCE: I bought a used LG Optimus Fuel from a friend that
What do you want to do? Unlock your phone to take the Straight Talk Card? If so then take it to a phone shop and they can unlock it for any network!
SOURCE: how to switch from boost to straight talk phone and keep my number. backup contacts. photos. etc,?
Boost will port or release your number to use with a different carrier, if you go to any Wal Mart they should be able to walk you through it
just take your old sim card out of old phone and put into new phone-no nee for number transfer.
