SOURCE: ICE MAKER NOT WORKING
Filters are a main problem with any kind of ice makers big or small...if filter is plugged up. Water can not reach ice maker and this will be main problem especially if you live in a high mineral deposit area. Change it if its been awhile (live since you moved in).
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
SOURCE: No water to the ice maker
Yeah, the valve is definitely not turned on. Just turn the valve and you should be good to go...
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
SOURCE: icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
