Turn ON the power switch with the Stop/Reset key held down. code is for the fuser the hot part that fuse the toner to the paper. Replace may be needed.
Restart the machine.If code removes then its OK, otherwise press the utility/counter button and restart the machine.Don not leave the button.Keep the button pressed.Trouble reset will appear on screen hit it and restart the machine.
your problem maybe caused by a thermistor near the pressure roll in the fusing unit (the red roll).
Try the follow procedure and if it doesn't fix call minolta service.
1. Turn OFF the Main Power Switch. 2. Turn Main Power Switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
